September 13, 2007, 02:35 |
Convergence monitoring!
I solving a jet impingement problem, (compressible Euler ) Computational domain is a trapezoid (i last plane has an inclination of 30 deg) with grids 31x25x25. CFL=1.0 iterations=200 cycles=5 (so 1000 iterations) I monitored the L2-norm , it initially drops but then at around 500-600 iterations it peaks and then drops off. For 2000 iterations there were peaks at iter no. 500-600 , around 1200 It almost seemed periodic. Any suggestions what must be causing this? Thanks
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Monitoring Convergence in Stirred Tank using MRF method | GOPINATH87 | Main CFD Forum | 0 | August 20, 2011 00:45 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Monitoring Convergence in Fluent 5.0 | Tom Plikas | Main CFD Forum | 0 | April 6, 1999 18:10 |
