High curvature 90 degree bend using SST, eddy viscosity drop??
Old   August 22, 2014, 18:26
Default High curvature 90 degree bend using SST, eddy viscosity drop??
tinab0binuh
tinab0binuh is on a distinguished road
Hi
I am simulating a radial centrifugal compressor inlet with a decreasing in area (0.5 area reduction), 90 degree bend with SST. Exit results show high entropy generation not just in the boundary layer but parabolic-like entropy generation from 20% span to the shroud. It seems that the shear strain rate is high and computing the reynolds stresses, those are at a peak around 80% span. The eddy viscosity is highest in the boundary layer, decreases below laminar values just outside the boundary layer and then increases again near the 80% span region.
Also, if I change my inlet turbulence properties (reduce the length scale by 90%, change the intensity from 5 to 10%) I get a change in eddy viscosity and NO CHANGE in entropy, even though the velocities at all points in the channel look the same !!
My question is... (1) in high adverse pressure gradient flows, are these problems in the eddy viscosity expected?? Most papers only discuss the boundary layer region. What happens to k-epsilon (the free stream equations of SST) in the FREE STREAM when subjected to pressure gradient??
Note: I am not using curvature correction.
Also: I have read that the k-e model is not sensitive to inlet turbulence conditions....but if the eddy viscosity is changing.. why doesnt the entropy generated change?
tinab0binuh is offline   Reply With Quote
curvature, entropy, k-epsilon, sst
moving coordinate system to center of 180 degree bend in flow 3d maryamak Main CFD Forum 0 March 24, 2014 12:39
[ANSYS Meshing] Inflation Layers around a 90 degree bend that is separated into multiple parts Kaaji1359 ANSYS Meshing & Geometry 2 August 18, 2013 19:57
flow with high turbulent viscosity ratio Phillips Main CFD Forum 2 August 25, 2008 19:01
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
High viscosity flow robert Main CFD Forum 0 September 10, 2002 10:43
