Get pressure from velocity
Like Tree1Likes
Old   August 21, 2014, 06:25
Default Get pressure from velocity
samycfd is on a distinguished road
Hi everyone,
What's the best solution to get the pressure field from the velocity field ?
Solving the pressure poisson equation (PPE) ?
( I will assume the boundary for conditions for pressure depending on each flows. )
Thank you very much !
samuel
samycfd is offline   Reply With Quote
Old   August 21, 2014, 08:56
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by samycfd View Post
Hi everyone,
samuel
is the velocity field divergence-free? If yes, you can solve the Poisson equation, however be careful your pressure will be defined apart a function of time
FMDenaro is offline   Reply With Quote
Old   August 21, 2014, 09:09
The velocity is assumed to be divergence-free ( the gradient of the out-of-plane component is very small ) .
I have solved the PPE but still get some wrong results compare to a fluent simulation. I am studying only steady cases so the time dependence does not matter.
I am using finite differences to compute the RHS of the PPE ( Lap(P) = ux^2 + uxvy + uy^2 ). Are there any issues there ? ( I am using forward differences ).
Old   August 21, 2014, 12:30
do you know the 3 velocity components in the same nodes of a Cartesian box? Are they equidistant?
First of all, check the (Div v) value in each node using central second order formula. Then, consider the steady momentum equation:
Grad (p/rho0)= Div (2ni*Grad v - vv)and take the divergence of both sides to write the Poissone equation for pressure.
Be carefull that boundary conditions must be properly posed on the frontier
Old   August 21, 2014, 14:01
The problem is that I not always know the three components. But if just know two of them, the case could often be assimilated to a planar case( in the flows I am going to study.. of course it's not always right!)
I have checked the divergence of the flow.
What represent ni and vv in your equation ?
If I take the divergence of both sides of the navier stokes equation
grad(P) = 1/rho * [ - grad(v) v + nu * lap(v)]
and assuming div(v) = 0 , then at the second order I get
lap(P) = - 1/rho * ( u_x^2 + u_x * v_y + v_y ^2 )
( where v=(u,v) and u_x represent the derivative along the x axis of u and so on .. )
Is that right ?
Old   August 21, 2014, 14:22
Is that right ?
but if you don't have the complete 3D velocity field the problem is big...
However, you have to discretize the equation as
Div (Grad P) = 1/rho * Div [ Div ( 2*nu *Grad v - vv)]
vv is the convective flux. You cannot assume div v =0 without ensuring that is numerically satisfied in each node
Old   August 21, 2014, 14:30
Yes of course but I am asked to qualify in which extent this assumption ( divergence-free) is still right by maybe defining a value for the divergence above which results will be wrong. But anyway I will deal with that and I have understood the problem.
So I will try this equation !
But I don't understand why I have to discretize the equation in this way ? Is the problem about numerical instabilities or convergence of the equation ?
Thank you very much for your answers !
Old   August 21, 2014, 15:15
If you integrate that equation over the surfaces of the domains, provided that the BC.s are correct, you satisfy the compatibility relation that ensures the existance of a solution.
If you want, more details are in http://onlinelibrary.wiley.com/doi/1...d.598/abstract
Old   August 21, 2014, 16:09
Do you know where I can find the full-text online ? Or could you send me the paper by private message ( because I ve figured out that you were the author ) ?
Thanks !
Old   August 21, 2014, 16:19
https://www.researchgate.net/publica...ns?ev=srch_pub
Old   August 21, 2014, 16:55
Thank you, I will take a look at it and try to understand all of that !
Best regards
Samuel
Old   August 22, 2014, 05:42
You would mean Div (Grad P) = 1/rho * Div [ Grad( 2*nu *Grad v - vv)] ?because we could not take the divergence of a scalar value.
Do you agree with the fact that the convective term is ( v . grad ) v ?
Thanks
Old   August 22, 2014, 05:45
Thanks
no, from the Reynolds theorem you write Div (vv) that is a vector (therefore you still can calculate divergence).... only if you use the mass equation then you can rewrite the momentum equation in quasi-linear form
Old   August 22, 2014, 05:53
I don't understand how is it possible, because the divergence returns a scalar ...
I don't get your point .
Before using the mass equation, after taking the divergence you normally get something like : div ( grad P ) = div ( nu lap(v) - vv )
Old   August 22, 2014, 06:11
no, vv is a tensor (as Grad v), therefore its divergence is a vector
The diffusive flux is 2*nu*Grad v, when you take the divergence it writes nu*Lap v only if Div v is fulfilled.
Therefore
( grad P ) = Div ( nu 2*nu*Grad v - vv )
-> Div ( grad P ) = Div [Div ( nu 2*nu*Grad v - vv )]
Old   August 22, 2014, 06:38
I have understood one part but why the convective term is a tensor ?
Grad v is a tensor, in 2D we get : Grad v = [ ux uy ; vx vy ] ( Matlab notation )
but the convective term defined as ( v . grad ) v gives a vector for me :
( v . grad ) v = [ u ux + v uy ; u vx + v vy ]
I must be wrong somewhere but I don't know why
Old   August 22, 2014, 09:03
the convective flux of the momentum quantity is a tensor as it represents the mass for volume unit (rho*v) macroscopically transported by the velocity field v.
I suggest have a reading of some basical fluid mechanics textbook
Old   August 22, 2014, 09:21
So you're talking of something different from the convective term in Navier-Stokes equation ?
Because for me it's that ( 3.1 section )
http://en.wikipedia.org/wiki/Navier%...e_acceleration
Old   August 22, 2014, 09:27
the difference is just in the conservative or quasi-linear form of the NS equations, however both v*Grad v and Div (vv) produce a vector.
For the formulation of a general transport equation, the Reynolds transport theorem is the corner stone. From that you can derive everything...
Have a reading of some good textbook, wikepedia is very poor...
Old   August 22, 2014, 09:42
I know it was just because there formula were written clearly.
In a lot of great books I found the Pressure poisson equation in 2D for a divergence-free flow as the following : ( approx ~ 2nd order )
laplacien(p) = - rho * ( (u_x)^2 + u_x * v_y + (v_y)^2 )
+ Boundary conditions
I want to be certain, you told me that it is not correct ?
pressure velocity
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
Initial pressure and transverse velocity fields to initialize turbulence model nickvinn Main CFD Forum 0 February 29, 2012 11:11
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 21:04
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 10:23
