Get pressure from velocity
Like Tree1Likes
Old   September 2, 2014, 10:53
samycfd is on a distinguished road
Sure.
I was confused, please forget the two last posts I wrote nonsense..
samycfd is offline   Reply With Quote
Old   September 5, 2014, 05:20
I tried to discretize the problem using the approach you gave me.
To compute axd and adc in [(axd-axc)i+1/2 - (axd-axc)i-1/2]/dx, I need to discretize them - what I did - but I need some BC also ? because n.(ad-ac) is only for the final step ?
I am confused..
Old   September 5, 2014, 05:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
No, just cancel out the terms in rhs and lhs of the equation when a section lies on a wall...You get a matrix with some lines modified according to neumann bc.s and the sourc e term modified congruently. That dose not imply You have fixed zero pressure normal derivative
FMDenaro is offline   Reply With Quote
Old   September 5, 2014, 05:30
No that's not what I mean,
I have to compute that ( 1D )
[(dP/dx)i+1/2 - (dP/dx)i-1/2]/dx = [(axd-axc)i+1/2 - (axd-axc)i-1/2]/dx
with the BC : dp/dn = n.(ad-ac)
But first, I have to compute axd and axc. And for that on the edges I need some BC, no ? Do I just let 0 on the edges ?
Old   September 5, 2014, 06:27
Yes, use not permeable and no-slip bc.s
Old   September 5, 2014, 06:51
this is only valid for the lid driven cavity, how to deal with that for an other flow ?
Old   September 5, 2014, 08:08
I guess it's not a solvable problem. but still I could assume that the value on the boundary is the same as the closest value. ( zero-gradient condition)
Old   September 5, 2014, 09:39
well, you can consider any type of bc.s, (inflow, outflow, etc), some details are here
http://onlinelibrary.wiley.com/doi/1...d.598/abstract
Old   September 23, 2014, 06:21
Thank you again for all your help.
I would like to know from where come the relation dP/dn = n.(ad-ac) ?
It's the Helmholtz Hodge decomposition ?
Old   September 23, 2014, 07:16
Yes, correct
Old   September 24, 2014, 05:30
I understood the definition of a projection operator which allows us to project any velocity field on his divergence free field. And then we apply this operator on Navier Stokes equation. But I don't understand the simplifications..
Here is the steady velocity field is w = - grad p - u(grad u) + mu lap u and then we compute P(w) ( P projection operator ) with hypothesis that div u = 0 ( divergence free) . But after I don't get it..to arrive to the pressure equation with BC
Old   September 24, 2014, 06:13
Just apply the divergence operator to all the terms in the steady momentum equation. This writes
Div Grad P = Div f
The key is that the momentum equation can be seen as the Hodge decomposition
Old   September 25, 2014, 03:44
Okay , so there is an analogy between :
divgrad p = div f
and
div grad q = div w
( if w = v + grad q , the field we want to project with div v = 0 ) .
But I don't understand for which mathematical reason we could get the same BC for p.
Old   September 25, 2014, 04:54
divgrad p = div f
and
div grad q = div w
To have a unique (apart a constant) solution, it is mandatory that the Neumann bc.s are imposed according to the Hodge decomposition, that is projecting the decomposition along the normal direction to the boundary. The divergenze-free constraint automatically set int[S] n.v ds = 0
Old   September 25, 2014, 05:12
I am confused. I read that http://www2.math.uni-wuppertal.de/~r...u/lecture6.pdf .
And on pages 9 & 10, to arrive to the same result they assumes no slip BC on all boundaries.
I was thinking it was working even without that?
Old   September 25, 2014, 05:26
To be well posed the HHD problem, only one bc must be provided.
For the pressure problem this condition accords with the mass flow rate, therefore the normal condition, not the tangential (no slip) is required.
The tangential condition is used for the HHD problem expressed in terme of vorticity and stream function
Old   September 25, 2014, 05:31
So I need to know all the normal BC for velocity to be able to write the equation for pressure with BC. so that's why in your paper you made different cases depending what kind of normal BC for velocity it is ..
Old   September 25, 2014, 05:33
I considered several possibilities, depending on the type of BC.s, you can or not ensuring a orthogonal decomposition.
Old   September 25, 2014, 06:02
I don"t see to what the case 2 (n.a diff 0 ) leads for the pressure ?
Old   September 25, 2014, 09:31
in this case you still have a decomposition but you can no longer demonstrate the unicity and orthogonality of the decomposition
pressure velocity
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
Initial pressure and transverse velocity fields to initialize turbulence model nickvinn Main CFD Forum 0 February 29, 2012 11:11
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 21:04
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 10:23
