August 13, 2014, 23:41 |
Does the grids topology matters?
Meimei Wang
Rep Power: 16 |
We suppose that we have two grids with different grids topology for the same geometry. These two grids match the requirements listed as below.
1. Converge to the same and very small residual value, e.g. 10^(-6), both globally and locally. The resulting factor we care about won’t change with more iterations anymore. 2. Both of them are tested to have very good grids refinement independence. 3. They all have very good grids qualities value, e.g. skewness, aspect ratio, grids expansion rate. 4. The solver and boundary settings are all the same. 5. Both of the grids are structured grids. I’m wondering, is it possible that they still give very different CFD simulation results? Does grids topology really matters to the results if the simulation matches all the theoretical requirements?
Best regards, Meimei Last edited by Anna Tian; August 14, 2014 at 03:11. |
August 13, 2014, 23:56 |
#2 | |
M. Nabi
Rep Power: 17 |
August 14, 2014, 00:36 |
Meimei Wang
Rep Power: 16 |
Grids independence includes grids refinements independence and grids topology independence. Grids refinements independence is one of requirements as listed above. My questions is about grids topology independence.
Best regards, Meimei |
August 14, 2014, 00:48 |
M. Nabi
Rep Power: 17 |
The grid topology doesn't affect the results so much as long as you have grid independence solutions.
August 14, 2014, 01:51 |
Meimei Wang
Rep Power: 16 |
What do you mean by your 'grid independence' here?
August 14, 2014, 03:07 |
M. Nabi
Rep Power: 17 |
I mean, your grid is fine enough, and refining the grid does not affect your solution.
In the coarse grid, the topology of grid may have big effect. For example, if you solve on two different grid, let us say, one Cartesian, the other curvilinear, the solution is dependent of several factors, such as the cell size, the location of nodes etc., But as your grids are fine enough, and the solution is not affected by the grid size, you have to get similar solutions. |
August 14, 2014, 06:27 |
#7 | |
Rep Power: 17 |
"Trying is the first step to failure." - Homer Simpson |
August 14, 2014, 20:21 |
#8 | |
M. Nabi
Rep Power: 17 |
August 15, 2014, 04:05 |
#9 | |
Rep Power: 17 |
Fair enough, and if properly implemented then I fully agree.
August 16, 2014, 10:33 |
#10 |
ABDUL GAFOOR CP
Rep Power: 12 |
hii..
i am doing diesel engine closed simulation by using AVL FIRE. For the grid independency test purpose,i have taken different average cell size with different number of cells for the same problem. after running some simulation with different cell size. i am getting similar results for some properties(such as pressure, temperature etc..) bt for the same case am getting different values for some other properties. so please suggest me the important aspects and care we should have to take before a grid independence test in AVL fire ESE diesel simulator. thanking you all Abdul gafoor please give me some suggestions to perform a grid independencey test |
August 16, 2014, 14:18 |
#11 |
Rep Power: 16 |
The result depends on the grid quality. If your solver is not bugged you should find exactly the same results for equivalent grids.
August 19, 2014, 02:20 |
#12 | |
ABDUL GAFOOR CP
Rep Power: 12 |
after completing some run with different number of cells....am getting a matching result within a range of number of cells....and a different result after that range.....so can we take the range at which we r getting same solution for our actual testing....is that a valid method...... please reply.... regards gafoor |
[ICEM] Refine All Mesh problem with hexahedral grids | FSVH | ANSYS Meshing & Geometry | 1 | August 13, 2014 16:36 |
Grids generation for airfoil with flap | Anna Tian | Main CFD Forum | 4 | December 29, 2013 05:58 |
[ICEM] Shifted Periodic topology | venkat_aero2007 | ANSYS Meshing & Geometry | 17 | August 27, 2013 01:41 |
attachDetach Topology Modifier: Proper Turbulent Boundary Conditions | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | September 13, 2012 04:56 |
A question about dynamic overset grids | JXIA | Main CFD Forum | 4 | January 10, 2008 03:50 |
