Negative Volume
Old   August 30, 2007, 06:51
Default Negative Volume
saurav pathak
can anyone kindly explain me what is meant by "negative volume" in a mesh?
Old   August 30, 2007, 07:43
Default Re: Negative Volume
rt
degenerated elements, reverse or inconsistence node ordering
Old   August 30, 2007, 09:23
Ahmed
How volumes are calculated?
the scalar triple product of vectores formed from the sides of a cell, the formula is found in any linear algebra book, play a bit with the numbers and see by yourself how could you get a negative volume. Some times the cell you are calculating its volume is not deformed at all, but its vertices are numbered clock wise, in this case remeshing is the only solution to this nasty problem
Old   August 30, 2007, 12:01
Anantha
It depends.. If you are using commercial tool like ICEM, you have the option of 'invert block' to get rid of this problem.. though the mesh will look perfect for eyes, we will get negative volume error because of the reason as said by Ahmed and some times you can fix it up by this block inversion method.
Old   August 31, 2007, 08:34
Charles
All of the above comments are true, but sometimes, when dealing with nasty geometry, hexahedral meshes can simply get folded, which will also show up as a negative volume. Imagine taking a rectangle, and twisting one edge through 180 degrees. So negative volumes can't always be solved by re-ordering. You may need to look a it to see if the cells make physical sense.
Old   August 31, 2007, 14:18
Joe
I'm assuming this is a structured or hex mesh. If all the volumes are negative, then your system is left handed. Reordering the indicies will fix that - easy. If just a few of the volumes are negative, then you have crossing grid lines - much harder. You need to find the location and source of the problem to fix this. Sometimes smoothing the mesh will an elliptic solver will work. But most of the time there is an underlying problem with your database or grid structure.
Old   September 1, 2007, 12:26
Default Re: Negative Volume come back
jorge
I have ansys turbogrid 10 in workbench environment, but this send a error when i want to do a mesh.(negative volume). I read many post about this(These advice move the master control points)but the problem is not solved. Help me.Please. Jorge
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
