August 22, 2007, 09:15 |
Fortran editor for Linux
Is there any editor with good support for fortran ? I am looking for an editor which has features to manage a big fortran project with multiple files. In Linux only.
August 22, 2007, 16:39 |
Re: Fortran editor for Linux
If you use the KDE environment you can use kdevelop to manage fortran projects.
August 22, 2007, 16:47 |
Now, I am using just the vim editor. It looks very simple and easy to use. However, one needs to memory some commands for the effective use.
August 23, 2007, 09:16 |
Once you are expert at VIM, no other editor can beat it. But I'm quite lazy and found myself stuck with NEDIT.
It's not a software management but pretty goot at multi-file editing. Syntax hightlight, statistic line and line numbering and other function made it useful in editing and debuging. |
August 23, 2007, 09:38 |
Emacs version 22.1 released in June (not the older one that comes with your distribution) is probably the best for most people. In this version a lot of the unconventional stuff has been replaced so that it points-and-clicks like a conventional editor, includes a gui driven interactive debugger plus, of course, the billions of lisp scripts to support indentation, highlighting, commenting, etc... To manage a large project one usually emacs interfaces to separate tools like subversion/cvs , make, etc...
August 24, 2007, 00:40 |
I go with Andy, I don't know the new version, but emacs is the best i know till now, but on debian. They have the tutorial online also, which you can study in few hours. The coloring of the syntaxes, commenting etc can be enabled for fortran itself.
Cheers |
August 24, 2007, 04:45 |
Thanks for all the suggestions. I have used only vim and I am usually happy with it. But now I am working with a huge fortran code. I would like to be able to easily navigate between different subroutines without having to search manually for them. I will try out emacs also.
August 24, 2007, 05:59 |
One thing worth knowing is the emacs itself has a VI emulator with user-settings for how close to VI it behaves. And you get the graphical benefits of emacs for free (point & click etc).
In emacs, use the command: "viper". (Stands for VI PERil) |
August 24, 2007, 06:03 |
#9 |
In vim you can use tags to jump around. In emacs you can use the speedbar which is usually off by default or tags if you prefer.
If you want a Windows-type integrated environment there is eclipse with the photran extension (or a word something like photran) for Fortran but it does not work 100%. Eclipse works well for Java, OKish for C/C++ but with Fortran support lagging somewhat. An alternative that is well sorted is the Sun Integrated Development Environment which fully supports java, c/c++ and fortran and in several instances has better programming tools than the gnu ones. |
August 24, 2007, 13:21 |
#10 |
emacs with speedbar looks interesting. Also taglist with vim/gvim also does similar job. In emacs I havent got indenting etc. to work well for fortran. Is there something I have to enable? Can somebody paste their .emacs settings for fortran?
August 24, 2007, 16:53 |
#11 |
: something I have to enable? The only problem I can recall concerned something called freeze which seemed to get triggered by a .F ending. What problems are you seeing with indentation? > Can somebody paste their .emacs settings for fortran? ;;Hopefully this turns off the freeze business for .F files (setq crypt-freeze-vs-fortran nil) |
August 25, 2007, 01:02 |
#12 |
Hi I am not expert on setting environments, some one set it for me & indenting work fine with me as long as the file is named *.f, .F, .F90, .for. etc.
May be look thru this .emacs file, mind you my setting deliberately disabled CVS since it was a bit of annoying to me. &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& &&& (mouse-wheel-mode t) (toggle-transient-mark-mode) (global-font-lock-mode 1) (custom-set-variables ;; custom-set-variables was added by Custom -- don't edit or cut/paste it! ;; Your init file should contain only one such instance. '(vc-handled-backends (quote (CVS SCCS)))) (custom-set-faces ;; custom-set-faces was added by Custom -- don't edit or cut/paste it! ;; Your init file should contain only one such instance. ) &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& &&& cheers taw |
August 27, 2007, 08:32 |
#13 |
If I am editing a file ending in .f it should automatically do the indenting. But it does not work. In viper mode indenting works but not fully. For example if I start a do-loop indentation occurs but for "enddo" the indenting is wrong.
August 27, 2007, 09:38 |
#14 |
It does not know you are going to type end do until you have typed it. If you press the tab after typing end do but before hitting return it will indent.
August 27, 2007, 09:57 |
#15 |
Thanks for that information. In vim I dont have to press tab at all. Indentation is fully automatic. As soon as I type enddo it is automatically correctly indented. But in emacs you have to press tab for every indentation.
August 27, 2007, 22:50 |
#16 |
A comment still if it will help,
Your approach is new to me. I do it as follows. I just type my script, select or highlight it. Then in emacs in the menu bar there will be "Fortran" bar. I select indent region or sub-program etc, may be yours is short, I will try it. Cheers, TAw |
Fortran Compiler-CFX12.1 | Araz | CFX | 13 | March 27, 2017 06:37 |
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 | hawk | Main CFD Forum | 1 | April 12, 2005 23:13 |
visual fortran | Monica | Main CFD Forum | 1 | August 28, 2004 21:45 |
Fortran77 or Fortran 90 | Swapnil | CFX | 2 | November 26, 2002 16:16 |
Why Favoring Fortran over C/C++? | Zi-Wei Chiou | Main CFD Forum | 35 | September 26, 2001 10:34 |
