Mesh element for velocity and pressure drop prediction |
July 23, 2014, 03:12 |
Rep Power: 12 |
If i have two wall with some 400 mm gap and air is flowing through it, how many element (in cross section) i should put in while meshing to get velocity and pressure drop. velocity is around 2 m/s and temperature around 200-300 degree Celcius. Is is ok to put 2-3 elements in it. thank you. |
July 26, 2014, 13:15 |
No, it is not. It slightly depends on your solver too, but I would probably go with at least 40 cells.
July 27, 2014, 11:03 |
Rep Power: 12 |
thank u lovercraft22. i am using fluent as solver. ( icem cfd as mesher) .
help in pressure drop calculation in fluent | sinaupdate | FLUENT | 3 | July 10, 2016 05:56 |
pressure drop in the pipe | mike.mm | FLUENT | 6 | February 7, 2011 10:31 |
Pipe Flow - Pressure Drop | Daniel L | FLOW-3D | 2 | December 10, 2010 04:23 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
