FORTRAN coding for AMR
Old   July 22, 2014, 16:07
Exclamation FORTRAN coding for AMR
Harshavardhana Srinivasan
harshasrini is on a distinguished road
Hello!
I am writing a code to perform Mesh refinement, i have a starcd mesh file (2d), i have written a code where i read the mesh file, i have the cell data and the vertex data read separately and have also defined the neighbours. I want to refine particular area of cells, maybe to create a circle and refine the cells that fall into it... i have also created the circle within the grid, am finding it difficult to write a condition to mark the cells that fall under the circle, it would be great if someone could suggest me a solution for this or any other strategy... Thanks in advance
harshasrini is offline   Reply With Quote
Old   July 23, 2014, 14:59
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Dear Harshavardhana,
your question is not easy to understand. The only thing which pops up in my mind is that you should check for (quantities in square brackets are optional for 3D):
given the coordinates x, y [, z] of the cell center (or any other relevant cell-related coordinate)
given the coordinates of the circle/sphere center xc, yc [, zc]
given the circle/sphere radius rc
if ((x-xc)^2+(y-yc)^2[+(z-zc)^2]>=rc^2) then
!Point out of the circle/sphere
else
!Point in the circle/sphere
endif
But i hardly think that after all that you did you stopped on this. So, please, elaborate more.
sbaffini is offline   Reply With Quote
Old   July 23, 2014, 15:04
Dear Paolo,
What i want to do now is to just test my algorithm for AMR, i dont have a solution where i can use the truncation error to flag cells for refinement, so am creating a circle within the grid and flagging the cells falling under the circle for refinement. I have created the circle and am stuck on how to flag the cells within the circle now... Or am looking for some-other way to flag cells for refinement..
Thank you.
Old   July 23, 2014, 15:40
sbaffini's Avatar
Paolo Lampitella
So, would the check suggested above work in your case? Or have i misunderstood your question?
fortran code, mesh adaptation, refinementregion
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
Using Fortran with CFX: How to connect Fortran to CFX? l.te CFX 0 October 21, 2012 12:42
Fortran CFD coding on Macintosh OS 9mile Main CFD Forum 2 August 23, 2009 02:38
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
fortran coding for explosion dj CFX 0 September 25, 2003 02:33
