Matthew
Rep Power: 0 ![]() |
Hello CFD community!
I would like to validate a CFD code against analytical solution. Do You know cases which could be used to validate solvers listed below: 1. Inviscid, Compressible 2. Laminar 3. Turbulent I would also appreciate any references on that subject. Mateusz |
le hoang anh
Rep Power: 13 ![]() |
You can use the simple case to test as 1/ oblique shock through the RAM 2/ Lid driven cavity: the results are avaiable fir both laminar and turbulence |
Sebastian Engel
Rep Power: 21 ![]() |
Hi Matthew,
check out the cfd-online wiki. http://www.cfd-online.com/Wiki/Valid...and_test_cases Many of those are stubs, but some references are available usually. Maybe you can share your experiences later and extend those articles. =) A more general list of validation sources is available in the links section http://www.cfd-online.com/Links/refs.html#validation With regards, Sebastian |
analytical solution, validation, verification |
nan "tke + specific dissipation" while restarting the SST solution | taxalian | SU2 | 9 | May 22, 2013 14:20 |
CFD verification and validation | Weiqing Xu | Main CFD Forum | 0 | March 3, 2012 08:25 |
New OpenFOAM Verification & Validation Forum Opened | jola | OpenFOAM Announcements from Other Sources | 2 | October 1, 2011 17:21 |
Verification | lr103476 | OpenFOAM Running, Solving & CFD | 1 | April 26, 2006 14:45 |
Validation and Verification | Ferreira, VG | Main CFD Forum | 0 | June 18, 2005 08:13 |
