staggered grid
Old   October 11, 1999, 14:27
Default staggered grid
Matteo Manganelli
Which is the advantage in using a staggered grid? Is it alwayas the best method?
Thank you.
Matteo
Old   October 11, 1999, 16:04
Default Re: staggered grid
Md. Ziaul Islam
A staggered grid is used for pressure and velocity cells to obtain convergent solutions where the fluctuations in the velocity and pressure, as well as the free surface instabilities need to be evaluated.
Old   October 12, 1999, 10:24
Yangang Bao
I think staggered grid is only valid for regular mesh(so-called structured grid).
I am using tetrahedral grid in 3D, and using colocated grid, it works fine.
Old   October 13, 1999, 02:06
Frank
A staggered grid is used to prevent pressure velocity decoupling which can occur on a collocated grid if certain measures are not taken.
Old   October 13, 1999, 09:49
Yangang Bao
pressure mode only occurs when you use the same low order of shape functions for pressure and velocity (velocity should be interpolated 1-degree higher than pressure due to NS equations) or when you use regular mesh.
Question regarding non-uniform FVM staggered grid quarkz Main CFD Forum 2 June 18, 2011 18:18
Staggered grid (sedimentation of solid particles) TTY Main CFD Forum 0 October 30, 2010 13:15
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 17:31
Semi Lagrangian method and Staggered Grid JEONG MO HONG Main CFD Forum 1 May 26, 2003 02:43
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
