MULTIGRID
Old   July 21, 2007, 14:34
Default MULTIGRID
Tiz
Hello everyone,
I am try to apply multigrid to a 2D Navier-Stokes Finite Volume solver. Although I am looking for a steady state solution, I solve the problem with a time marching approach. I manage to code the problem in a 1d simpler case, but moving to the 2d proved more complex than I thought. Any suggestions on how to do this?
Thanks in advance
P.S. I obtained the adjoint equation for the coarser grid. Once linearised, this looks very similar to the equation solved in the fine grid, but the coefficients are now multiplied by the corrections rather than by the actual variables. Everything works well in 1D, but I have serious troubles in 2D
Old   July 22, 2007, 01:23
Default Re: MULTIGRID
student
are you solving linear or non linear equation. and what type of problem are you solving.
Old   July 22, 2007, 06:40
Tiz
I am solving the full Navier-Stokes equations in a tube with a time marching approach. Of course this means nn linear equations ...
Old   July 22, 2007, 17:07
dontknow
I recommend the paper by Raw: A coupled AMG fpr the 3D Navier-Stokes equations. It is a rather simple AMG which I also implemented. It is not based on very subtle mathematical approximation but on physical conservation properties. It is one of the most useful papers I ever read! Also the Algebraic Multigrid Tutorial by Briggs, Cormick and Henson is a very good literature about multigrid methods. Further the page www.mgnet.org.
Hope, this helps...
Old   July 23, 2007, 09:48
Tiz
Actually I am trying to use geometric multigrid rather than algebraic ... do you have a copy of the paper? Could you please send it to me?
Thanks
LES by Multigrid mnabi Main CFD Forum 8 July 11, 2009 21:21
multigrid sureshkumar Main CFD Forum 0 June 9, 2006 02:20
Multigrid method Suresh kumar Main CFD Forum 1 April 24, 2006 21:07
MULTIGRID at the wall Jim Main CFD Forum 0 February 19, 2003 13:22
Multigrid applied to k-e models Paulo Zandonade Main CFD Forum 9 May 24, 1999 09:10
