Accumulated drag and lift
Old   June 29, 2014, 20:53
Default Accumulated drag and lift
ryan298 is on a distinguished road
Hello everyone,
I have a question regarding the accumulated drag curve shown in the figure below for the CFD simulation of external flow over an automobile
It can be seen in several regions that the accumulated drag curve is dropping (ie., having a negative slope, for instance, as in the region between 2500 and 3500 for the x axis). Now this should mean that in those regions, the drag is negative locally, as only this would bring a reduction in the overall drag. But how is this possible,? How can drag be negative locally in the said region for instance?
Correct me if I'm misinterpreting the curve.
PS: 1) The figure I've posted here is taken from a source which I've referenced below
"Levin, Ridgal, Aerodynamic analysis of drag reduction devices on the underbody for SAAB 9-3 by using CFD, Master's thesis, Chalmers University of technology, 2011"
2) It is kind of urgent, so if someone could help me out ASAP, it would be great
File Type: png Screen Shot 2014-06-29 at 7.44.15 PM.png (79.6 KB, 31 views)
ryan298 is offline   Reply With Quote
Old   June 30, 2014, 09:41
agd
agd is on a distinguished road
The total drag is a combination of pressure drag and viscous drag. The pressure drag can be negative or positive depending on the local pressure relative to free stream.
agd is offline   Reply With Quote
Old   July 1, 2014, 12:08
Thank you agd!. I understand better now
automotive aerodynamics, drag coefficient
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
[OpenFOAM] Display lift and Drag in paraview SamerAli ParaView 1 May 16, 2013 13:51
[ANSYS Meshing] Lift & Drag Meshing Techniques tylerplowright ANSYS Meshing & Geometry 6 May 3, 2012 00:53
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 11:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
