Small Discretization Example for 2d Tri Mesh
Old   July 14, 2007, 15:31
Default Small Discretization Example for 2d Tri Mesh
Fab
I most of the cfd numerics books (e.g. the book by Versteeg and W. Malalasekr) there are FVM examples for discretization of a diffusion equation applied on a quad mesh. Does anyone has an idea, where I can find some good explanations for tri and tetra meshes? Somehow, I have trouble to imagine the derivation of the discretization equation for unstructured meshes...
Regards! Fab
Old   July 14, 2007, 21:00
Default Re: Small Discretization Example for 2d Tri Mesh
Harish
There is a book by Lohner Applied CFD Techniques: An Introduction Based on Finite Element Methods.It has detailed explanation of the whole process.
Old   July 15, 2007, 07:30
Ahmed
The book you are referring to is an introduction to the finite volume method, unfortuanetly it explains a special case of the FVM applied to structured cartesian grids(I have the first edition, and have no plans to look at their second edition), If you want to understand the FVM you have to look at the book by Blazek
Old   July 15, 2007, 07:40
Ahmed
The title of hte book by blazek: Computational Fluid Dynamics: Principles and Applications
Old   July 17, 2007, 08:50
Ford Prefect
Well the 2nd edition contains a chapter on unstructured grids with illustrative examples. It also explains how to use Rhie and Chow velocity interpolation for co-located velocity arrangement instead of a staggered grid arrangement. If you liked how they explained things and how they approached problems, then I would recommend the 2nd edition. If not, well then there are a lot of other books out there.
Old   July 18, 2007, 03:25
Ahmed
Thank you kindly
Old   July 22, 2007, 11:44
Fab
Hi to all,
thanks, I will take a look at Blazek's book ...
Regards! Fab
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Tri Mesh In ICEM CFD Mohammad Faridul Alam CFX 0 January 16, 2008 07:33
