Comparing Air numerical results with water experimental results |
June 28, 2014, 06:54 |
George
In my work plan I have to Compare Air numerical results with Water experimental results to study the mixed convection effects on the flow structure in a simple geometry.
I appreciate all answers Thanks in advance and kind regards |
July 2, 2014, 18:11 |
Rep Power: 144 |
Yes, this is normal. It is a standard engineering approach - and is the reason scale models can be built to accurately reproduce the flow fields of the full sized device. See Similitude (http://en.wikipedia.org/wiki/Similitude_%28model%29)
Coupled DPM water spray inside enclosed volume of air | dan86 | FLUENT | 0 | July 19, 2013 11:23 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 2 | November 27, 2012 21:36 |
AIR or Water | HMR | CFX | 6 | April 7, 2011 03:28 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Comparing Experimental and Computational results. | New | Main CFD Forum | 0 | September 27, 2007 12:08 |
