July 12, 2007, 12:58 |
Supersonic Combustion Fluent
Hello, I am modelling Supersonic Combstionn with Fluent.
I started with a 2d case Coupled Implicit solver, and every thing was pretty fine. The CFL number had to remain under 1 though ( slow convergence, anyway). Now I try to do the same with a 3d calculation, a,non-reactant flownd it is VERY Slow. I am currently computing a mixing case. What should I do. Is it a problem linked to Couple or Implicit solver? I have like 420 000 nodes for a fine grid and 120 000 nodes for a coarse grid. I use k-epsilon. I refined the coarse grid with gradient adaptation and with the refine grid there is this message at each iteration: " reversed flow in 44 faces on pressure outlet 3 turbulent viscosity limited to viscosity ratio od 1.00000+5 in 2cells" That did not appear without refinement and it does not appear for the fine grid. Does it slow down the calculations? Many thanks, Alex |
July 12, 2007, 13:11 |
Re: Supersonic Combustion Fluent *NM*
July 26, 2007, 17:49 |
Fluent recommends SA model for high speed flows ... I have run with that .... if u are interested in turbulent kinetic energy/dissipation rate ... u can converge with SA and then switch to Kepsilon... it is possible to get unrealistic results about turblence production and viscosity ratios ... look only for the quantites u require and match with expts ...
I have faced same problem with turbulence predictions reverse flow should vanish as the iterations progress |
supersonic combustion in Fluent | argeus | FLUENT | 2 | April 2, 2023 07:39 |
Assistance for modelling unsteady supersonic flow in FLUENT | SATISH A.V | FLUENT | 11 | October 1, 2014 23:36 |
combustion of particle in fluent | Devy | FLUENT | 0 | March 13, 2003 06:12 |
Can I use Fluent to stimulate diesel combustion | Allanhill | FLUENT | 1 | March 6, 2003 08:46 |
which combustion model can be in supersonic field | cfdfans | FLUENT | 0 | March 9, 2001 23:13 |
