convergence of density-based solver for unsteady flow
Old   June 16, 2014, 12:37
Default convergence of density-based solver for unsteady flow
Jianguo
zhengjg is on a distinguished road
I use Fluent to resolve unsteady subsonic flow (Mach number = 0.27) around a stalled naca0012 airfoil with chord length based Reynolds number of around 1.5 million. The density-based solver with 1st order implicit time stepping scheme is employed.
The vortex shedding frequency is known. For each shedding cycle, 50 time steps are used. However, with the density-based solver, the solution cannot be be converged after more than 50 sub-iterations for each time step. However, for the pressure-based solver, the solution is converged in around 10-20 iteration for each time step.
so, why does the density-based solver not converge and how can I solve the convergence problem of density-based solver?
Any suggestion is welcome.
Thanks!
zhengjg is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Fluent Adjoint Solver Convergence Issue? ex10148 FLUENT 2 July 25, 2016 15:41
parallel code samiam1000 SU2 3 March 25, 2013 05:55
Pressure gradient in UDF for density based solver matzb FLUENT 0 February 22, 2010 07:34
Segregated flow solver and no convergence Ankit Purohit Siemens 0 June 15, 2007 10:22
