Airfoil Heat Transfer Near Leading Edge
Old   June 28, 2007, 13:53
Default Airfoil Heat Transfer Near Leading Edge
Glenn
Colleagues... I have a Y+~1 mesh (with associated near-wall mesh spreading), running with the RKE w/ wall enhancement for P,T turbulence modeling. The analysis runs around an airfoil section. The flowpath is turbulent (Intensity ~ 5%, dissipation lengh specified), compressible flow. Since I have a refined wall mesh, the boundary layer is integrated to the wall through the mesh, and heat flux = K*dT/dY at the wall. Does FLUENT therefore return a laminar heat flux (and HTC)result near the airfoil leading edge region, indicative of a newly forming boundary layer? If not, what tells the solver to produce a non-laminar near leading edge heat flux? (ie: how does FLUENT know not to provide a laminar value?) Thank you for your insights. Glenn
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
CFX Heat Transfer RJamison CFX 0 July 24, 2008 13:11
heat transfer in two-phase flow Leonid Fromzel CFX 0 April 8, 2008 06:57
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
