wrong drag and lift at high AoA
Old   June 12, 2014, 10:15
Default wrong drag and lift at high AoA
lucaoggi
lucaoggi is on a distinguished road
i am running both URANS (2D and 3D) simulations on a s809 airfoil at very large AoA (ca. 60 degrees) and constantly over-predicting C-lift and C-drag.
I am a bit puzzled about it since i tried pretty much everything but i wanted to ask in her if some of you has been working with any type of bluff body flows (cylinders, flat plates at high AoA) and has been experiencing similar problems. In this article Pellegrino seems to have similar problems http://www.tara.tcd.ie/xmlui/bitstre...pdf?sequence=1
so i am starting to wonder if it is quite common to get wrong lift and drag values.
Thanks in advance
lucaoggi is offline   Reply With Quote
des, high angle of attack, s809, urans
multiple runs for lift and drag at various AOA ShowponyStuart CFX 8 April 29, 2020 09:03
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Wrong Drag and Lift Coefficient when changing AoA inspiron FLUENT 1 November 27, 2013 14:00
Correct values of drag but high values of lift. aamer Main CFD Forum 16 December 16, 2010 05:44
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
