Axial Flow Fan-Selection
Old   June 11, 2014, 01:34
Default Axial Flow Fan-Selection
tamil nadu
Anandltvs is on a distinguished road
How would you select an axial flow fan of desired frame for automotive radiator application from the market ? Obviously we will select the best performing fan.When you don't get performance parameters such as flow rate,pressure etc from vendor how would you choose the fan from fan blades profile,apperance etc...
Anandltvs is offline   Reply With Quote
Old   February 3, 2016, 08:36
karrenshaw9 is on a distinguished road
Parag’ Fans & Cooling Systems Limited, India’s largest and one of the world’s leading manufacturers of Energy Efficient Axial Flow FRP Fan System and other related components since 1987
karrenshaw9 is offline   Reply With Quote
Old   February 12, 2016, 07:50
miguel pace
impactgroupusa1 is on a distinguished road
An axial flow fan, as the name indicates moves the air/gas parallel to the axis of rotation. Comparing it with the radial or centrifugal flow fans move the air in perpendicular direction to the axis of rotation. The axial flow fans are more suitable for high flow and low resistance applications, while the other fans are simply appropriate to the opposite conditions– low flow and high pressure resistance. The axial flow fans vary in terms of operating features depending upon the blade shape and width along with the tip speed and number of blades in it. These are typically used to cool systems and machines like spot cooling and area ventilation.
if you are looking for more information visit on: impactgroupusa.com
Impact Cooling Solutions
impactgroupusa1 is offline   Reply With Quote
Old   February 12, 2016, 10:09
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Seems obvious, but usually the price tag should also be considered
...choose different vendor. It is their job to tell you what their product does.
flotus1 is offline   Reply With Quote
fan driven flow, Fan BC validation (getting lost) soonic OpenFOAM Running, Solving & CFD 0 July 7, 2013 20:16
Axial fan Efficiency Goals calculation? Sanghyun - PARK FloEFD, FloWorks & FloTHERM 1 February 18, 2013 12:20
BoCos for axial fan modelling Catthan FLUENT 0 February 5, 2013 07:13
Air flow simulation in volume with fan and opening koziymf FLUENT 0 November 14, 2011 18:44
Question about flow in ducted fan in another duct Jane FLUENT 0 June 21, 2004 14:57
