DES and LES meshing: tips and advice?
Old   June 21, 2007, 10:56
Default DES and LES meshing: tips and advice?
James M
I'd like to enquire if any of you can advise me on a tutorial or guidelines on grid generation for DES and LES problems. I understand the meshing is different than RANS, more complex and delicate so I turn to all the great scientists and engineers of the forum for some help!
Thank you in advance.
James
Old   June 25, 2007, 04:57
Default Re: DES and LES meshing: tips and advice?
qwerty
Do not mesh! Just generate a continuous substrate of solids/fluids in your 'domain'. Discretized mesh has to be eilminated. Continuum 'mesh' is the way to do it.
p/s: dont take this too seriously
Old   June 25, 2007, 11:23
James M
I see... Is there any particular reason as to why discretized mesh is not welcome? What about the boundary layer?
Thanks
Old   June 27, 2007, 14:43
jojo
Do a RANS simulation first. Extract the integral scale and prepare your LES mesh such that your mesh size is about 1/10 of this scale. As for boundaries, refine your mesh to make y+ of order unity close to the wall (LES).
DES and LES meshing: tips and advice? James M FLUENT 3 June 24, 2007 21:22
