Solving 2D Euler equations over a neutral airfoil |
June 6, 2014, 14:36 |
Erik
Hi, I am trying to code the euler equations to solve supersonic flow over a neutral airfoil using the MacCormack explicit predictor-corrector finite difference scheme but I get strange results that make no sense. I tried to run my solver with a simpler domain (3 by 3 domain with the middle point being the point that I want to solve) but I have the same problem as with the airfoil in that the results show convergence but it is clear that the answer is not correct.
I don't want to upload tons of information and I would rather upload what you might think will be relevant. My code was written in matlab. |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
