y+ (respecting the estimated wall distance)
Old   May 28, 2014, 17:21
Default y+ (respecting the estimated wall distance)
LOTFI OULD ROUIS
zomayabssa is on a distinguished road
When you got for example an estimated wall distance of 5E-6 using the CFD ONLINE tool, does it matter if you use a smaller value in your mesh such as 3E-6 or the mesh has to begin exactly from the estimated value?
Thanx in advance guys,
Loffy
zomayabssa is offline   Reply With Quote
Old   May 29, 2014, 03:35
ahmed
ahmed_khatibs is on a distinguished road
CFD online helps you to approximate the values, you may get help:
http://www.cfd-online.com/Forums/mai...lus-value.html
regards,
Ahmed Khatib
ahmed_khatibs is offline   Reply With Quote
Old   June 1, 2014, 12:47
N/A
harishg is on a distinguished road
For turbulence models which can be used in the visous layer, having y+<=1 can ensure convergence of results. So having a smaller value is fine. However, some of the models may have certain restrictions on the validity of their damping functions/ corrections. You might need to check the documentation for the specific model.
harishg is offline   Reply With Quote
Old   June 5, 2014, 14:39
LOTFI OULD ROUIS
Thnx for these suggestions guys!
Old   June 6, 2014, 00:26
Thiagu
jthiakz is on a distinguished road
sometime it is possible with meshing tools, but after importing in solvers with some low tolerance, it might show some errors.., so make sure you have fine mesh with reasonable quality. let us know if it works.
Also refer the turbulence modeling requirements.
jthiakz is offline   Reply With Quote
first element, icem, mesh, meshing, y+ turbulence
calculating wall distance wallDist volker OpenFOAM Programming & Development 12 December 28, 2017 12:29
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 05:15
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 11:24
distance to wall in given direction nikwin OpenFOAM 3 February 16, 2012 10:27
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
