Peetak Mitra
Rep Power: 14 ![]() |
What effect does very high reynolds number flows have on the turbulence viscosity ratio? Is it safe to increase the upper limit in cases which involve Re in the range of 1000000 to 9000000? I am constantly getting the warning for the turbulence viscosity ratio being limited to 1+e5, but I read on some blogs online that it can be expected to be higher for high reynolds number flows so will it be safe to increase the upper limit in such cases? Thanks, peetak |
fluent, high reynolds number, viscosity |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
Temperature loss in compressible solvers in high speed flows | vkrastev | OpenFOAM Running, Solving & CFD | 1 | June 16, 2018 07:10 |
Derivation of the pressure-correction equation for compressible flows | luftraudi | Main CFD Forum | 0 | July 17, 2012 06:35 |
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 02:23 |
