calculation of value of convective heat transfer coefficient for a bank of cylinders
Old   May 26, 2014, 04:13
Default calculation of value of convective heat transfer coefficient for a bank of cylinders
sid
sidrameshrath is on a distinguished road
hi guys
I am new at using ansys and the problem i have in hand is to find the cooling time for a array of cylinderical wires from 80degree celius to 50 degree celius
the conditions are
laminar cross flow over the cylinder
forced convection
I somehow managed to get the empirical fomulation of convective heat coefficient for a single wire using empirical corelations
but what should i do find the h for a in line configuration of cylinderical wires
I read that it can be done using CFX ansys but i am unable to do it
I know that the h will vary as the air flows over the cylinders in one row
Please help
an early response will be appreciated
Please if anyone has any idea kindly do share
I am in deep trouble and not getting any help
sidrameshrath is offline   Reply With Quote
Old   June 10, 2014, 05:35
Rami Ben-Zvi
Rami is on a distinguished road
Hi sidrameshrath,
Have a look at works of Zukauskas, e.g., in the book
A. Zukauskas, Heat transfer from tubes in cross flow, Advances in Heat Transfer (Eds. Hartnett, J. P. and Irvine T. F.) 18, 87-159, 1987.
or a book named Tube banks in crossflow by the same author.
He covered this topic.
Rami is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 4 January 24, 2017 15:30
calculation of value of convective heat transfer coefficient for a bank of cylinders sidrameshrath CFX 1 May 31, 2014 00:42
Distribution of surface heat transfer coefficient along the axial direcion of a tube andred FLUENT 0 November 16, 2010 22:13
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
