May 26, 2014, 11:54 |
#21 | |
Huang Xianbei
Rep Power: 14 |
I want to do a channel flow DNS using Nek5000, if you have more documents or something helpful to learn this code, I'll be very very thankful |
May 26, 2014, 14:50 |
#22 |
Unfortunately, that's all i got to learn Nek5000. However, at least one of the manuals is not that bad and you can use the examples to start using it. For example, there is a channel flow example which should be perfect for you. Obviously, as i said, this i snothing close to a commercial code anymore, and you have to look at the code to know what the subroutines do. However, compared to large codes like OpenFOAM, i found it very simple to understand, considering that you don't need to manage the core part of the code.
May 26, 2014, 20:55 |
#23 | |
Huang Xianbei
Rep Power: 14 |
May 27, 2014, 06:20 |
#24 | |
May 29, 2014, 10:15 |
#25 |
Also PowerFLOW can do DNS.
https://www.exa.com |
dns |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
CFD code structure (F90) | ma | Main CFD Forum | 4 | January 10, 2005 21:47 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 16:56 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 18:25 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
