fortran77 help
Old   June 11, 2007, 09:05
Default fortran77 help
khan
I am using fortran 77 and looking for a function/subroutine which help me to generate many data files automatically to be used for animation. Now I am doing it manully but make me tired.
e.g i need to rename p.out as p1.out,.. p1.out ->p2.out ....pn-1 ->pn.out after every 5o iteration.
any one can help me.
thanks
Old   June 11, 2007, 12:18
Default Re: fortran77 help
MM
Use the following command:
write(filename,'(a3,i4.2,a4)')'RES',NUM,'.OUT'
OPEN(2,FILE=filename)
Write(2,*)...
Close(2)
Just put the above in a loop while NUM is changed for each output file. You should make files such as: RES 1.OUT, RES 2.OUT and ...
Old   June 11, 2007, 15:24
Lost in CFD
Can this syntax be applied to Fortran 90??
I've been opening several files, then
open(50,.) open(51 open(52 ...
do i=50,whatever asdfasdf
write(i,*)
end do
this would make things much easier if I could use it in 90.
Old   June 12, 2007, 01:24
Markus Lummer
It works also in Fortran 90.
fortran77 or 90 hosseinhgf CFX 2 November 26, 2010 02:02
How can I find a free Fortran77 numerical library? Alberto Main CFD Forum 3 January 21, 2008 01:56
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
