Why Re is diff for external and internal flow?
Old   June 10, 2007, 23:32
Default Why Re is diff for external and internal flow?
john
We know that Reynold's no is different for internal flow and external flow? I wonder why does it happen? Is it the charecteristic length, which is different in both and so Re is different in both?
Old   June 13, 2007, 03:58
Default Re: Why Re is diff for external and internal flow?
Anton Lyaskin
If you are talking about critical Re, then it's really because of characteristic length. To compare them directly you'll need to use boundary layer thickness for external flow, instead of body size
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh denner OpenFOAM Meshing & Mesh Conversion 3 October 13, 2011 10:24
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 04:07
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 18:12
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 04:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
