EMMS in fluent 14.5 diverging problem
Old   May 21, 2014, 10:56
Default EMMS in fluent 14.5 diverging problem
jipaz is on a distinguished road
Hi Everybody:
I'm simulating a 2D Fluidized Bed Riser in Ansys Fluent 14.5 using an Eulerian approach, k-e turbulent model, Johnson-Jackson wall boundary condition. When I use some drag model included into fluent, I havo no problem about the convergence, but I can not obtain the proper mass flux profiles into the riser, so I tried to use the EMMS drag model as an UDF, I compiled it well, without any error message, but when I started the calculation procedure, before the first iteration I got the following error messages:
Updating solution at time levels N and N-1.
done.
iter continuity u-aire u-solidos v-aire v-solidos gt-solidos vf-solidos time/iter
mp-x-momentum equations:
Divergence detected in AMG solver: pressure correction
Divergence detected in AMG solver: vof-1
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 3: floating point exception
I test my problem using the modified Syamlal-O'Brien drag model example, and the run progress properly, so I understand that the problem is the EMMS UDF, but I don't know what I should do. Any help is very welcome.
Regards
jipaz is offline   Reply With Quote
diverging, emms, fluent, riser
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
