Blade Thickness Distribution w/ Blade Distortion
Old   May 21, 2014, 10:38
Question Blade Thickness Distribution w/ Blade Distortion
Tristan
twolfe13 is on a distinguished road
I have an in-house code written in MATLAB that requires a blade thickness distribution file (x,y tab delimited text format). I want to specify inlet and outlet blade angles (beta1 & beta2) which will distort the blade and generate a camber line. My question is two-part:
1) How should the camber line be generated from inlet and outlet blade angles? I have a few methods in mind, but I'm having trouble finding a general accepted method. Spline? Polynomial? Etc.
2) Once this camber line is generated, how do I modify the blade thickness distribution of a common (NACA 6 series) airfoil to generate a new blade thickness distribution?
I originally thought that the blade thickness distribution would not need to be modified since it's measured perpendicular to the camber line anyway, but that results in a very ugly airfoil (kind of diamond-shaped with a tear drop profile at the LE & TE).
The problem is that the code is embedded in an executable that I do not have the source code for, so I can't actually see what's going on inside the black box to try to reverse engineer this.
twolfe13 is offline   Reply With Quote
Old   May 22, 2014, 01:10
A. S.
apoorv is on a distinguished road
There are many common meanline for turbomachinery blades : Circular arc, Quadratic, Cubic, Parabolic and now a days NURBS/Bezier curve based meanline.
Similarly there are many thickness distribution equations; but NACA distribution is not much preferred now a days. Other few are multiple circular arc distribution, British C-series distribution. Now a days Nurbs distribution is also common.
I have few text input driven fortran based 2d/q3d/3d direct design code for my own use. If you need 2d version, may be I can help. Please drop me a personal message.
Best Regards
Apoorv
apoorv is offline   Reply With Quote
blade angles, blade distortion, blade thickness, camber line
Plot pressure distribution on a section of 3d blade Dr.been FLUENT 2 July 22, 2016 06:03
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 10:47
static temprature distribution in turbine blade sam Main CFD Forum 0 February 19, 2007 13:33
Blade thickness on propeller wash prediction Lam Main CFD Forum 1 October 28, 2005 03:36
