problem in Phase Field method
Old   June 9, 2007, 03:33
Default problem in Phase Field method
qunwuhe@hotmail.com
I used Phase Field method simulating a bubble movement. However, when I plot the streamlines, I found some of the streamlines across the interface, which means some fluid flows across the interface. However, I simulated the incompressible and immisible flow.
Does anyone can tell me the reason and how to solve it
Thanks a lot
Old   June 9, 2007, 04:34
Default Re: problem in Phase Field method
rt
maybe "parasitic current" is a reason,
this is problem of modeling capilarity two-phase flow with eulerian approaches, there are some treatement for VOF method, see this for a survay:
http://scholar.google.com/scholar.bi...II&oi=citation
Old   June 9, 2007, 04:47
qunwuhe@hotmail.com
I am not sure whether it is because of Phase Field method I used. For parasitic flow, when surface tension is weak, the effect should be negligible. I decreased the surface tension, there still is across flow.
Old   June 9, 2007, 09:02
rt
- note that phase field is not essentially release from parasitic current.
- note that surface tension is not good measure, better is working with dimensionless numbers and change them, weber, frude ... and study effects.
- also without surface tension we have some current too.
Old   June 9, 2007, 11:32
dusky.He
Concerning second, I increase We number by one order. It is almost the same.
Maybe I should try Level set method and check it.
Old   June 13, 2007, 04:09
rt
Level set is good, but migration from phase-field to level set ! (so why u select phase-filed, level set was trivial choice at first)
anyhow, i think that false current should be smaller in phase-filed than VOF (because we don't have such discontinuty that is in VOF, also filtering of phase-field variable can be tested) and probably u can manage it with phase-filed, i don't knowe whose phase-field model u r used but, phase-field has several parameters that should be adjusted to give correct result, so u have good opportunity to do more with phase-field and then put it away, also it can be see as an original and interesting work.
Old   February 16, 2011, 13:20
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Hi all,
I am thinking of using Phase-field modeling in my case, a Taylor bubble moving in a channel. As far as I know, OF did not support this phase field modelling. Can you please share your experience of which solver is most similar to that method as a starting point?
Regards,
Duong
duongquaphim is offline   Reply With Quote
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 09:25
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
phase field or Cahn-Hilliard method dusky.he Main CFD Forum 3 February 2, 2006 17:43
Differences between VOF and phase field 2L Main CFD Forum 2 July 4, 2004 14:30
pressure field problem. michal FLUENT 1 March 18, 2004 15:45
