WAVE Ricardo Software
Like Tree1Likes
Old   November 3, 1999, 20:46
Default Re: Ricardo & WAVE
  #41
T.J. Wanat
I've ask at work if anyone has successfully simulated flow noise and the answer was no. It may be necessary to use direct numerical simulation instead of a turbulence model to capture the pressure fluctuations, unless there is a way to back them out of k and epsilon, but I'm only hypothesizing.
Old   November 4, 1999, 04:27
  #42
Joern Beilke
Even DNS does not work, because the pressure fluctuations we call sound (what we can hear in the far field) are some orders of magnitude lower than the turbulent pressure fluctiations in the flow (sometimes called pseudo sound).
Old   March 26, 2010, 03:57
Default Looking for technical assistance with WAVE
  #43
jehad
jehadyam is on a distinguished road
Hi
I am not gonna get involved with the "useless" discussion about the accuracy and performance of simulation software. If anyone has better software, he should come forward and compete in the market.
I am facing problem simulation hydrogen engine. The software cannot accept hydrogen as "Gaseous fuel.
If anyone can help i will be thankful. I got excellent performance compared with experimental using gasoline fuel with Ricardo E6/T Variable Compression Engine. I am now interested to do the same with hydrogen fuel.
Any suggestions Plz.
Best regards
jehadyam is offline   Reply With Quote
Old   November 29, 2016, 14:05
Default Calculate the mass fraction burned
  #44
jehad
Hi
I am using Ricardo Wave 2016.
I am simulating 4-Stroke diesel and SI engines.
I am interested to calculate the exergy loss during cycle.
In that I need the mass fraction burned, unburned heat loss, burned zone heat loss.
Any clues?
Old   November 25, 2018, 05:50
Default Multifuel using Ricardo
  #45
jehad
Hi
I am trying to simulate SI engine performance using multifuels(Gasiooline+H2+Ethanol).
I allwaysget douple peak on my P-V and other diagrams
Any clue.
I tried all possible combinations of wiebe fuenction
Old   May 31, 2019, 05:24
Default Dual Fuel
  #46
jehad
Hi
Has anyone tried to simulate the performance of SI engine using Alcohol + Gasoline as fuel
Wave Rotor simulation popezmark OpenFOAM 8 February 4, 2014 19:00
active wave absorb(about wave tank) zhaochuangang ANSYS 0 September 22, 2010 03:29
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 17:57
what is the condition to use the wave equation? mmff Main CFD Forum 0 January 26, 2010 05:25
Question about the shock wave in CFX software nucharin Main CFD Forum 1 January 25, 2005 09:26
