June 6, 2007, 20:57 |
Heat Exchangers NTU relations
Hi all,
I am modeling heat exchangers. I am looking for Heat exchanger effectiveness relations & Heat exchanger NTU relations for 2-PASS CROSS FLOW exchanger both fluids unmixed. I want to compare numerical results with semi-analytical solutions. I cant find them in any book. Most give for single pass exchanger. I am wondering if such relations exist for 2-PASS exchangers. Any references are appreciated. Thanks in Advance. |
June 7, 2007, 00:16 |
Re: Heat Exchangers NTU relations
For a 2-pass cross flow unit, split the exchanger in half & model as two units in series. This is standard practice in the industry.
The performance & pressure drop is the same. mw |
June 7, 2007, 04:33 |
Try looking Heat Transfer (Second Volume) by Jakob, it is an old book but full of excellent information, Good Luck
June 8, 2007, 09:42 |
Thanks to mw & Ahmed for your response. MW made an very good suggestion. I might just do that!
June 9, 2007, 02:01 |
The suggestion I made is standard design practice in the htd (heat-transfer device) industry. Refer to Ralph Webb for instance. It is logical & it works in practice.
Best of success. mw |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
Heat exchangers and Microchannel coils | MM | Main CFD Forum | 2 | September 17, 2007 06:47 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Which CFD Package for Heat Exchangers? | Michel | Main CFD Forum | 3 | December 18, 2003 17:34 |
