Fully-developed heat transfer in annular passages with arbitrary wall temperatures |
May 19, 2014, 04:47 |
Rep Power: 17 |
Hi all,
as you might guess from the title, I am trying to do a simplified calculation of heat transfer for a concentric gap between two pipes with different (but uniform) wall temperatures under forced gas flow conditions. So far I found in VDI-Wärmeatlas, 1997, Gb1 only correlations for heat transfer with identical inner/outer wall temperatures and a paper for the laminar case [Coelho & Pinho, 2005]. Any idea on which correlation I could apply for the transitional/turbulent case? Thx in advance! |
correlations, heat transfer, literature |
external wall heat transfer | ashghan | OpenFOAM Pre-Processing | 16 | October 27, 2015 21:29 |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 22:41 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 06:25 |
Heat transfer coefficent for the coupled wall | jing113cn | FLUENT | 5 | February 24, 2010 04:12 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
