May 9, 2014, 18:34 |
Yplus to high at Boundary Outlet
Daniel Frederik
Rep Power: 12 |
Hello People
I was analysing a heat exchanger ,two tubes one Inside the other, counterflow. The outer Flow is turbulent Re=300'000. Yplus is ok in general just at the outlet it reaches about 600. I tried to replace the boundary with an opening that didnt help. What do you do in such cases? Would you make the tube longer and that way taking it out of the analyzed length? What else could be done? Thanks in advance .. In the picture only a fourth of the tube is visible, i worked with symmetries... Last edited by Daniel Frederik; May 10, 2014 at 09:55. |
May 10, 2014, 10:53 |
Daniel Frederik
Rep Power: 12 |
could somebody change this into the CFX Forum, i didnt want to have it here, my bad..
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
Solver error message!!! | IoSa | CFX | 1 | September 14, 2006 05:48 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
