May 7, 2014, 21:21 |
Heat Transfer Coefficient of air vs Velocity
Rep Power: 13 |
The heat transfer coefficient of air is normally 100 W/m^2K at medium velocity.
And all know that the heat transfer coefficient is a function of air velocity. How high can the heat transfer coefficient increase with the velocity? Shree |
June 10, 2014, 04:08 |
Rami Ben-Zvi
Rep Power: 17 |
Hi Shree,
The HTC (heat transfer coefficient) depends on the flow configuration (e.g., flow on a horizontal or vertical flat plat, flow in a duct, etc), the flow being developed or developing, laminar or turbulent, the Reynolds and Prandtl numbers and surface roughness. There are many correlations for the HTC (e.g., Dittus-Boelter) giving explicit relations for Nu (Re, Pr) for various configurations at given ranges of Re and Pr (see, e.g., Ozisik or Holman books). If you choose an appropriate correlation for your problem, you will be able to estimate the HTC. |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
air distribution and heat transfer | wasim_kassel | FLUENT | 0 | June 24, 2013 12:12 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
