Motor air friction loss(windage loss) modelling
Old   May 4, 2014, 22:53
Default Motor air friction loss(windage loss) modelling
yang
yida16 is on a distinguished road
Hi Forum,
I am trying to model the air friction on the rotor of a motor. I am using Fluent I tried to use the MRF approach similar to wind turbine simulations (rotating fluid, stationary wall relative to fluid) I also have a stator and a stationary air region outside
I am not using any inlet and outlet just because I am not sure how the air flow axially. So I put walls on the two ends of the stationary air. Now my problem is that I don't really see torque on my rotor. Are my settings correct? Or should I even use the MRF? Because in my case it is actually the rotor that's pushing the air not the reverse as in wind turbines. Or should I add inlet and outlet? I am not sure how to set them, I tried with pressure inlet and pressure outlet with zero pressure on both but that gives me similar result as the wall case.
I have been working on this for a while and must get it done really soon. I appreciate your help!
Thanks,
yida16 is offline   Reply With Quote
Old   May 6, 2014, 10:50
yang
anyone know the solution to this?
fluent, friction, mrf, torque, windage
UDF for modelling heat loss in 2D Shrinand Fluent UDF and Scheme Programming 2 February 29, 2016 06:50
Convective heat loss out of a solar receiver construction Lionel Trébuchon CFX 10 April 6, 2014 21:25
loss calculation in simulation of turbomachines playmaster Main CFD Forum 0 August 21, 2010 06:59
modelling heat generation occourred by friction Ruggero Pellegrin CFX 0 February 11, 2005 07:29
head loss due to friction faisal FLUENT 0 April 23, 2001 05:13
