CFD used to obtain general formula
Old   May 9, 2007, 19:29
Default CFD used to obtain general formula
Marcin
I have a question about general application of CFD. In case an analytical or "semi-analytical" formula is determined by other ways, CFD can be used to confirm it. I've heard this is often used. How about getting a formula from CFD simulations that would have varying input parameters. Is this applied too?
Thank you, Marcin
Old   May 13, 2007, 03:06
Default Re: CFD used to obtain general formula
ztdep
I don not understand you ! We use the analytical results to validate the CFD solution
Old   May 14, 2007, 13:59
Marcin
Yes, but how about situation, where you do not have an analytical result. You get CFD solutions and then make a formula for flow (might we call it empirical) Would it be appropriate approach, when analytical solution is not that easy to find.
Old   May 14, 2007, 22:38
ztdep
I think i is appropriate to do that, but the cfd solutions should be validate by experimental data.
Old   May 15, 2007, 13:31
Marcin
Thank you!
please help me for general description of CFD Jiyeon Main CFD Forum 3 April 7, 2009 17:20
CFD Code Choice and General Advice Alex Pope Main CFD Forum 26 April 25, 2007 12:54
General CFD Question sam kashan Main CFD Forum 15 June 18, 2002 10:21
General Intro Course on CFD? J. Garroni Main CFD Forum 0 September 15, 1999 10:15
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
