Density based compressible flow solution
Old   May 6, 2007, 05:30
Default Density based compressible flow solution
Ahmet
Hi all,
I made a converging diverging nozzle solution with density based solution. But I can not get the correct results. I have a big differance between mass flow inlet and mass flow outlet. I tried lots of thing but I could'nt the problem.
Thanks a lot for helps.
Old   May 6, 2007, 12:22
Default Re: Density based compressible flow solution
George
Because the flow is compressible, this difference is a reasonable result.
Old   May 6, 2007, 13:36
Dominic
Probably you can try refining the mesh and see whether this condition persists. You should also try the flow inside a rectangular channel (parallel walls) to see if mass_in=mass_out.
Old   May 6, 2007, 13:44
ll
You mean that, because of compressibility, there is no more mass conservation ?
I don't think it is a reasonable result.
Old   May 6, 2007, 20:19
Djeghri Noureddine
Hi Ahmet
it is your code or you use a commercial CFD software ?
Old   May 6, 2007, 21:28
ag
I would look at my boundary conditions, and also check to see if total enthalpy is being conserved. Also, try running without boundary conditions to see if your solver can maintain a uniform freestream in the absence of boundary conditions.
Old   May 7, 2007, 02:21
Ahmet
I use Fluent. I made better mesh but I got the same problem. I think there is mass conservation also in compressible flow.
Old   May 7, 2007, 04:26
Dominic
Plot (mass_out - mass_in) as a function of time and see whether this difference is still dropping when you had taken the reading.
Old   May 7, 2007, 04:56
andy
What you are calling "mass" and what your commercial code is conserving via the mass conservation equation may not be the same thing. Look in the manual and find the form of the continuity equation at the end of the solution procedure:
* what is numerically conserved?
* where is it numerically conserved (e.g. face or centre).
* does it include pressure smoothing terms?
* are there splitting errors at the end of an iteration?
When you check your boundary conditions the same questions apply.
Old   May 7, 2007, 06:15
George
In transient calculations Mass_in will not be equal to Mass_out. For steady-state calculations the inlet and outlet mass will be equal. Is your code for transient calculations?
Old   May 7, 2007, 09:44
  #11
Mani
No mention of unsteady application; assume classical steady-state Laval nozzle: Of course, the mass flow has to be conserved as Ahmet expects. No question.
Ahmet, how do you evaluate the mass flow? Could there be an error in your evaluation? Could you examine the cross-sectional mass flow at any axial location, and if yes, does the mass flow vary continuously inside the nozzle or is there a jump in mass flow right at the boundary? How well is it converged?
How big is "big", i.e. what is the relative difference between the inlet and outlet mass flows?
If this were true, it would be a HUGE embarassment for the Fluent guys, but because this is such a standard test case and surely has been evaluated many times I am guessing that there is something wrong in your setup and/or post-processing.
Old   May 22, 2007, 04:48
  #12
reza
hi i need the information about compressible flow solution by ansys cfx.
Compressible flow modeling in Fluent nikhil FLUENT 8 August 9, 2011 15:18
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
incorrect temperature in pressure based solution Kian FLUENT 1 July 6, 2009 06:59
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 05:22
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
