what is the meaning of the following c code
Old   May 5, 2007, 10:08
Default what is the meaning of the following c code
ztdep
Hi The code are as following:
" double **matrix;
matrix = (double **) malloc (N * sizeof (double));
for (row = 0; row < N; row++)
matrix[row] = (double *) malloc (N * sizeof (double));"
i do not understand these four lines , would you please detail it. Regards
Old   May 5, 2007, 10:49
Default Re: what is the meaning of the following c code
Luca
it is the usual way in C to create a 2D matrix A. you can access to its element like matlab simply requiring: A[i][j]. Luca
Old   May 5, 2007, 11:41
Dominic
Suppose you say double *A. This means A will hold the address of a variable. You will allocate memory like: A=(double *)malloc(sizeof(double)*N); and *A will give the value at the first address. Then subsequent values can be obtained by *(A+1), *(A+2), etc....
Now lets say double **A. This tells *A will hold the address of a variable. You will allocate memory like:
A = (double **)malloc(size(double)*N);
Actually u are allocating memory for N rows only. The column part hasnt been allocated yet. So For each Row of A, that loop you mentioned will allocate for all N columns:
A[row] = (double *) malloc (N * sizeof (double));
The above will allocate space for N columns when row=0,1,2...N etc. So ultimately at the end you wud have allocated memory for a NxN matrix.
To find the value at the ith row and jth column of the matrix, just issue, *(*(A+i) + j).
-Dominic
Old   May 5, 2007, 12:17
ztdep
Thank you all for your excellent explaination.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 06:48
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 12:02
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
