code for large scale fluid induced movement
Old   April 27, 2007, 16:42
Default code for large scale fluid induced movement
sb
I am working on modeling a compressible, turbulent, supersonic flow problem that involves the large scale motion of multiple components of a mechanism (motion is large relative to length scale of the moving bodies) where the body motion is driven by the fluid induced forces (pressure and viscous) as well as user defined resistance, spring etc forces.
I need to be able to apply user defined mass and heat sources that are functions of current flow variables and locations in the system.
I also need to apply a real gas model.
I have looked at CFX but have found the mesh motion limited to small scale motion due to the main use of the grid stretching.
I have spent a long time trying to get FLUENT to work. WHile the motion and user functions suit the needs, the run times are unreasonable and parallel scaling with a moving deforming mesh is poor.
Does anyone have any experience in modeling this type of a problem, reccomendations for a code, or comparisons to the run time using FLUENT.
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
