request
Old   April 26, 2007, 08:08
Default request
jyothi
1- Why is the need to apply CFD? 2- What are the major advantages and disadvantages of using CFD? 3- What is modelling a physical process means? Why is it essential? 4- What are these items mean in terms of CFD: Discritization, Numerical Grid, Initial Conditions, Boundary Conditions, Sweep, Convergence and Turbulence Modelling.
PART II The overhead projector shown in Figure (1) was found to have an overheating problem of its glass flatbed due to prolonged use. As a computational fluid dynamist, you were asked to study the problem, simulate it and suggest solutions. Figure (1) Simulate the system on the Phoenics CFD Package and present your results in a report format. Make all the necessary assumptions.
Old   April 26, 2007, 08:32
Default Re: request
Ben
DO YOUR OWN WORK!
Old   April 26, 2007, 09:52
Default Re: request
barik.
http://www.google.co.in/search?hl=en...d+to+apply+CFD%3F&meta= This is the link which tells ur first part. Now go to key board, type www.google.com. and type ur other questions. Go to each link. May be u can find some link.
Old   April 26, 2007, 14:28
Default Re: request
pc
But it's so much easier to be spoon fed, Ben!
Old   April 26, 2007, 22:32
Default Re: request
Indiana
Jyothi, Since you have already solved the problem, why don't you post your solution here and ask for help in corrections? The way you ask your questions make it seem that you just want somebody else to do your assignment! Ethics is a subject taught in undergraduate engineering.....
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
Request to provide information Sanjay Jain FLUENT 1 December 31, 2007 06:40
Request for Book online is equivalent to piracy Noname Main CFD Forum 20 July 4, 2005 19:39
