April 18, 2014, 17:58 |
Interface conductance modeling
Marco Bernardes
Rep Power: 17 |
Dear all,
I'm looking for some approach to model interface heat conductance within OpenFOAM context. It refers to the ease with which heat can be transferred across an interface between two surfaces which are in contact. Any help is appreciated. Thanks, Marco. |
July 25, 2018, 11:53 |
asdf;lkj
Rep Power: 8 |
There is no support for contact resistance the easiest way to do it is by inserting a thin region of elements and adjust the conductivity of these elements to give the correct contact resistance.
if you found any other method to do please let me know |
interface conductance, openfoam 2.1.x |
Phase Field Method & Diffuse Interface Modeling in FOAM | holger_marschall | OpenFOAM Programming & Development | 13 | December 19, 2019 01:54 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Frozen Rotor 1:1 Mesh Connection | pharley | CFX | 5 | January 31, 2013 17:15 |
Interface Model:None or zero thermal conductance? | mak86 | CFX | 6 | October 12, 2010 23:15 |
Modeling Aircraft-Inlet-Wing interface | Riaan | Main CFD Forum | 0 | August 26, 2005 12:45 |
