reg:Pressure dependencies with velocities
Old   April 25, 2007, 10:53
Default reg:Pressure dependencies with velocities
Palani
Hi ! I am doing 2d-flow past a cylinder (Unsteady-incompressible) Large Eddy simulations in fluent and try to capture the Pressure Fluctuations for 4 differnet velocities (dia,density, distance from the cylinder all are constant ) at a point located at the wake.
In regarding this , I would like to validate my meshes on the basis of Pressure fluctuations captured at my reciever location. In connection with that, I need some theoritical relations between Pressure and Velocity (and Dia and Distance also accounts)
In M.M.Zdravkovich , I have found that Average of the Fluctauting (P')2 is proportional to the fourth power of velocity. How can I fix a value of theoritical Pressure on the basis of Velocity????
Will be the following relation will be a valid one ... since my density is constant
(P ')2 = (RHO)2 * (V)4
If not, Please reply me , if anybody knows some thoeritical stuffs....
Old   April 25, 2007, 12:15
Default Re: reg:Pressure dependencies with velocities
Mani
I don't see why you need a modeled relation between pressure fluctuation and velocity. Doesn't your CFD solution include both pressure and velocity? Why not get the pressure fluctuation (and/or velocity) directly from the unsteady flow field?
Old   April 25, 2007, 18:58
Lam
You may use the energy equation that energy will always be constant.
potential energy + pressure energy + kinetics energy = constant
z + P/pho.g + v^0.5/2.g = constant
if the z =constant, then the pressure is inverse proportional to the velocity.
Artificial high velocities at the interface using interFoam Arnoldinho OpenFOAM Running, Solving & CFD 38 October 31, 2024 09:00
how to get relative velocities in a rotating frame of reference? alkochevsky OpenFOAM Post-Processing 14 May 31, 2017 07:05
Interfoam Microchannel flow parasitic velocities cfd_user2011 OpenFOAM 2 June 12, 2011 16:43
Conversion of computed velocities in Lagrangian coordinates to Eulerian coordinates SMM STAR-CD 4 June 5, 2011 10:20
Derived velocities from loss coefficients ?? jakjak CFX 1 December 20, 2007 15:38
