CFD over rectangular wing with multi winglets
Old   April 17, 2014, 16:17
Default CFD over rectangular wing with multi winglets
Geetesh Waghela
geeteshwaghela1234 is on a distinguished road
hey, i am simulating flow over a rectangular wing of semi span 300mm and chord of 75mm at the root with taper ratio as 1.
i want to validate with the wind tunnel results.
i have used naca 0015 airfoil.
i have used spalart-allamaras turbulence model and inlet velocity as 20m/s, outlet gauge pressure as 0.
rest everything is set as wall.
i am getting floating point error mostly and when i reduced reference values by half, my continuity equation is diverging in range on 1e+05.
what can i do now to converge the solution??
i would like to proceed for multi winglets after i get this right.
geeteshwaghela1234 is offline   Reply With Quote
Old   April 23, 2014, 06:49
venki
venkateshaero is on a distinguished road
wch solver your using ?
venkateshaero is offline   Reply With Quote
Old   April 23, 2014, 15:34
Geetesh Waghela
i am using ansys fluent 14.5
i tried using k omega sst model also for solving but the results i am getting are varying from experimental data.
since the domain is restricted to a particular size, will it be accurate to use spalart allamaras model?
divergence detected, reversed flow, spalart allmaras, wing
Multi element wing CFD glp1e11 ANSYS 0 January 21, 2014 15:49
CFD of Wing on fixed Angle of Attack samuelcarlo CFX 7 August 4, 2013 08:09
CFD of conventional wing with a winglet? mimi Main CFD Forum 0 December 7, 2006 10:52
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 09:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 09:45
