entrance of a flat plate
Old   April 24, 2007, 23:38
Default entrance of a flat plate
mc
Now, I am investigating the flow around the entrance of a 2-D flat plate having endge-shaped (45 degree) leading endge. The thickness of the plate is 20mm, so bottom line of the plate is 20mm longer than the top line of the plate.
The Reynolds number is around 10^6. And the plate in installed at the centerline of a circulating tunnel have a test section dimention(height 450mm, width 150mm and length 700mm).
It was measured that there are not-small vortex flow starting the leading edge below the plate. And the reattachment point and height of the separated flow is varying in time.
I can't find any reference about it. Could anybody suggest some reference ?
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 22:09
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 08:56
drag of flat plate with cavity Far FLUENT 0 May 18, 2010 05:57
Questions about a Turbulent Flat Plate Case tstorm FLUENT 2 August 11, 2009 15:16
Conjugate heat transfer for film-cooled flat plate Michele FLUENT 0 July 3, 2006 09:42
