Impinging Jet and Turbulence Model Comparisons |
April 15, 2014, 13:55 |
Mark
Rep Power: 13 |
I have conducted a study and simulated an impinging jet in Ansys Fluent with three models. SST, K-Epsilon Standard and Spalart. For the wall jet I have chosen 4 distances increasing the distance from the stagnation point to measure the radial velocity.
I am just in the process of comparing all the models to the LDA data I have collected and it appears that despite all the research I have done the Spalart model has the closest agreement with the experimental data. I was just curious, of the three models, based on previous research and reading, am I right in saying the SST should have performed better due to it using a combination of K-Omega and K-Epsilon models? When I look at my SST model it appears that both the Spalart and K-Epsilon Standard have better agreement. Can anyone help me understand why this maybe? I have looked at possible grid refinements and conducted a Grid Independent study before hand. I am just trying to understand the physics behind it as I am new to CFD. Many thanks MM |
April 15, 2014, 16:42 |
Filippo Maria Denaro
Rep Power: 73 |
hello,
could you plot the results? how do you compute the statistical velocity from LDA? |
April 16, 2014, 09:22 |
Mark
Rep Power: 13 |
Here are the results as non-dimensionalised XY plots as requested. If someone could point me in the right direction as to possible resaons for diffreences that would be fantastic?
Thanks again. MM |
April 16, 2014, 12:23 |
Rep Power: 73 |
without details about the LDA measurement is not possible to give insight...especially the values measured around r->0 are suitable?
furthermore, you should put together the different solutions on the same figure for several r/D values. |
jet impact turbulence model choice | lolo3133 | Main CFD Forum | 0 | July 4, 2011 14:05 |
Slot jet impinging on cylinder | Diz | CFX | 0 | September 24, 2007 22:34 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 07:12 |
Turbulence model for supersonic jet | Danny Tandra | Main CFD Forum | 3 | August 24, 2001 05:10 |
a low Re number model for impinging jets | mahesh prakash | Main CFD Forum | 14 | September 3, 1999 17:40 |
