April 15, 2014, 11:45 |
Rotating Geometry
Tomys
Rep Power: 14 |
Hello CFD Online,
I need to model in essence a concentric cylinders made of metal plates with about 20mm air gap between. I will be flowing air through the gap while the cylinder rotated. The air at inlet will enter at steady continous flow. I had the geometry drawn and figured out. The problem is making it on ANSYS Fluent to measure its effectiveness and heat exchange rate. Can anyone please tell me if it is possible to model it with rotating geometry? All I am finding is fluid flow in pipe flow but haven't found anything where the pipe actually rotates while fluid flows through. Regards Mechfries. |
April 16, 2014, 02:15 |
Tomys
Rep Power: 14 |
Anyone? I need help. please.
April 16, 2014, 09:10 |
DaveyBaby
Rep Power: 13 |
Try posting this on the Ansys users forum
April 16, 2014, 09:27 |
Tomys
Rep Power: 14 |
Thanks. Doing it.
April 16, 2014, 15:14 |
nima vaziri
Rep Power: 15 |
Try "rotating flow in annular cavity" key word e.g "http://www.tandfonline.com/doi/abs/10.1080/10618562.2012.677039#.U07Hviimerg"
April 16, 2014, 15:20 |
Tomys
Rep Power: 14 |
Thanks for the link but I'm in no mean of purchasing that document.
I found this if anyone cares https://ujdigispace.uj.ac.za/bitstre...pdf?sequence=1 Going to need to do a bit more research to have multiple concentric cylinders which rotate in sync |
Animation of rotating geometry | freddyk | STAR-CCM+ | 1 | December 20, 2012 08:29 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 11:45 |
Rotating geometry test case | zebra | Main CFD Forum | 0 | August 25, 2010 11:34 |
Rotating Geometry | Gearb0x | OpenFOAM Running, Solving & CFD | 0 | July 1, 2010 12:57 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
