Hybrid mesh generation
Old   April 16, 2007, 15:19
Default Hybrid mesh generation
Jake
I have been tasked with moderating a session on hybrid grid generation techniques and need to come up with some talking points. As I am not very familiar with the hybrid gridding strategy I am hoping to get some input from this community. I am most interested in answers to the following questions:
How long does it take to generate an acceptable hybrid grid compared to other grid strategies?
How long does it take to converge a CFD solution on a hybrid grid compared to other strategies. For this question, the grids used for comparison should provide the same "accuracy" of CFD solution.
Which commercial or open packages are good at hybrid grid generation? Which is best?
Are there any situations where hybrid grids can't be used?
Are there any other issues I am overlooking?
By "other grid strategies" I include overset (structured and unstructured) and non-overlapping block structured.
Thanks in advance for your input.
Jake
Old   April 16, 2007, 19:12
Default Re: Hybrid mesh generation
Pagey
Talk to the people at ARA Ltd., they do a lot of hybrid meshing.
www.ara.co.uk
Old   April 21, 2007, 15:27
John Chawner
Jake,
Your hybrid meshing session should be pretty interesting given the current state of the art. For the record, I'll assume hybrid means prism-tet or hex-pyramid-tet, or hex-prism-pyramid-tet. Structured means mapped hexes. Unstructured means tets. Furthermore, I'm going to assume that we're talking about viscous as opposed to inviscid simulations.
: compared to other grid strategies?
This question might be easy to answer if not for the word "acceptable". In general, I would say that generating a hybrid mesh is faster than generating a structured grid but slower than generating an unstructured mesh.
If acceptable implies accuracy, I know people who refuse to use hybrid meshes on the grounds that they produce inaccurate results. If acceptable implies efficiency, I know people who refuse to use hybrid meshes because the solvers are slower and use more memory. In both cases, these people use structured grids instead. And I'm not talking about single users; these are entire companies.
Take a look at the results from the most recent AIAA Drag Prediction Workshop. That should give you some background on the various meshing strategies and solution techniques.
The promise of hybrid meshes relative to structured grids is the ability to generate a mesh for a viscous simulation much more rapidly. The price one pays for that level of automation is having to deal with quirks in the resulting mesh.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 16:20
Star-Design: Volume mesh generation error fusij Siemens 0 November 6, 2009 13:43
hybrid mesh Fabrizio FLUENT 4 August 16, 2006 07:41
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
