Airfoil Shape Optimization using gradient based methods
Old   April 10, 2014, 05:13
Default Airfoil Shape Optimization using gradient based methods
shikhar
jaiswal is on a distinguished road
Hi frnds,
I want to write a code for airfoil shape optimization using gradient based methods. I have read some journal papers regarding this, but im unable to figure out how to start. I have good knowledge of CFD, but im not much aware of optimization, parameterization etc...
Is there any text book, paper, reference or guide which explains airfoil shape optimization using gradient based methods in detail covering optimization and parameterization also.
Can anyone of you help me through this???
Share your experience or codes which will help me write my code???
jaiswal is offline   Reply With Quote
Old   April 10, 2014, 12:22
Default You may want to start here
vijaymali's Avatar
Vijay Mali
vijaymali is on a distinguished road
Send a message via Skype™ to vijaymali
Hi Jaiswal,
There are two ways I guess to approach this problem
1) A long way and 2) A short way
Long way is that you write code for all the required pieces. Short way is you use available pieces and just integrated them together for your optimization problem.
I guess following would be required pieces
1) Parametric definition of airfoil geometry and geometry creator
2) Mesher
3) Solver and post-processor
4) Optimizer
I think the first way would be too long to take. I suggest to go for second method.
I can think of following tools
1) Parametric definition of airfoil geometry and geometry creator - ANSYS GAMBIT
2) Mesher - ANSYS GAMBIT
3) Solver and Post - ANSYS FLUENT
Both above tools has journal feature. So you can automate everything. Find good gradient based optimizer (I guess there are many).
I wrote this code long back and not sure where it is now. But I will try to find and see how can we share that.
You may would like to go through this paper so get some idea about the optimization I tried
Optimization of L/D for ONERA-M6 Wing Using ADIFOR and EULER
Vijay
vijaymali is offline   Reply With Quote
Bezier-Bernstein approximation for airfoil shape DoHander Main CFD Forum 10 April 23, 2014 07:21
Face based gradient calculation Bernhard Kubicek Main CFD Forum 1 February 12, 2008 17:34
fan performance based on blade shape balaji Main CFD Forum 1 September 16, 2005 12:56
fan performance based on blade shape balaji Main CFD Forum 0 September 15, 2005 08:24
Unstructured Pressure Based Methods Apurv Main CFD Forum 2 July 6, 2000 21:31
